Regular Contributor I
CPPM serial number
How do I find the serial number of a ClearPass VM from the GUI as I need to raise a TAC case. I don't have access to the CLI at the moment.
Re: CPPM serial number
I'm pretty sure you can view it by clicking on the ClearPass version number at the bottom of the GUI.
Cheers
James
Clicking on the version number brings a box with some useful information but the serial number field has "none" next to it. I suspect this is probably because its a VM. I have managed to raise a case using the Subscription ID though so I have managed to overcome the hurdle.
Hey, if its a VM there will be no serial number (see below from a VM). If you provide the subscription key to TAC when logging a ticket they will be able use this instead of a serial. Hope this helps :)
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
