Occasional Contributor I
CRS for SSL CERTIFICATE from Clearpass
Hi guys.
2 questions.
I need to purchase a ssl certificate from thawte but the form is asking me server platform.
ARUBA CLEARPASS doesn´t apears but APACHESSL does.
what platforms can I choose ?  apachessl ?
they ask for CSR , where can I generate this CSR from Clearpass
Re: CRS for SSL CERTIFICATE from Clearpass
You can use Apache as the option. The csr can be generated under certificates at the top right
Tim Cappalli | Aruba Security
Hi Cap.
thank for reply,
so you mean certicate under policy manager, with http server certificate option ?
thank for your help.
Correct. Make sure you document the private key password. You'll need it to import the signed certificate.
Hi Cap.
I did it step by step , I just waiting for the signed certificate.
I appreciate your help.
