CVS to XML conversion tool for ClearPass
We had an CVS to XML conversion tool we used for mass import of device into Clearpass 6.3. We just did a double upgrade over the weekend going up to vesion 6.5. Since the upgrade to conversion tool no longer works. is there a new tool or some other way to import devices into clearpass. These aere our IOS devices that can't be authenicated by AD. so we import them and list the as District owned for MAC authenication.
Re: CVS to XML conversion tool for ClearPass
https://ase.arubanetworks.com/solutions/id/91
Thank You,
Troy
Trusted Contributor I
exactly what i need in a couple of weeks, thanks.
