Frequent Contributor II
Can I do Clustering between Clearpass Hardware Appliance and Virtual Machine appliance ?
Can I create clustering between Hardware and Virtual Machine in clearpass and How many server can be in one cluster?
Re: Can I do Clustering between Clearpass Hardware Appliance and Virtual Machine appliance ?
Yes. Currently 40 nodes.
Tim
Tim Cappalli | Aruba Security
Moderator
We have no HARD limit to the number of nodes in a cluster. We've QA'ed 40 but the REAl limit is more of an operation/design issue related to the DB replication/# of auths etc.
Take a read of my Cluster Guide for guidance. CPPM TechNote - Clustering Design Guidelines V1
Best Regards
-d
ClearPass Product Manager
