MVP
Can I enable 802.1x + mac auth in front of radius on the same VAP?
Hi Guys,
can I enable 802.1x + mac auth in front of radius on the same VAP?
Is it possible.
Config example or vrd containing the exact config will be helpful!
Thanks in advance,
Me.
Contributor I
Re: Can I enable 802.1x + mac auth in front of radius on the same VAP?
You should have a look under "Mixed Authentication Modes" in Aruba OS UG 6.1, page 323.
There is a command in the AAA-profile called l2-auth-fail-through;
"Use l2-auth-fail-through command to perform mixed authentication which includes both MAC and 802.1x authentication. When MAC authentication fails, enable the l2-auth-fail-through command to perform 802.1x authentication."
Christian Nilsson, Network Services
ACMA, ACMP, AWMP, Aruba Instructor, ACMX #159
