Frequent Contributor II
Can't "forget" wireless network on iPad after using Quickconnect client
Hi:
I've used the Quickconnect client to setup a wireless connection on an iPad, and now there's no option to "forget" this network.
Does Quickconnect remove this, and if so, do you know how I can get it back?
Tony
Community Administrator
Re: Can't "forget" wireless network on iPad after using Quickconnect client
You may need to delete the profile since QC installs the profile on the device.
(grabbed off google)
 To remove the wireless profile from an iOS device:
  1. Go to Settings > General > Profiles
  2. Select the profile you wish to remove (eduroam or UI-Wireless-Setup, for example)
  3. Select Remove
  4. If asked, enter your device’s security PIN number
Airheads Community - The best place to Connect. Engage. and Learn.
You need to delete the profile under General > Profiles.
This applies to IOS and OS X
Tim Cappalli | Aruba Security
Excellent.
Thank you.
