Can use self-signed https certificate on clearpass for guest captive portal login?
HI, Can use self-signed https certificate on clearpass for guest captive portal login?  If the guest self-register page in clearpass, will the guest see the security alert when he tries to connect to guest wifi? Please advise, thanks in advance.
Re: Can use self-signed https certificate on clearpass for guest captive portal login?
No, you need a public CA-signed certificate.
Tim Cappalli | Aruba Security
Thanks for your reply.  "public CA-signed certificate"  can be issued by company own AD CA server? or have to buy from outside CA authority?
No, public CA.
