Can we integrate IAP cluster with clearPass guest management to work with Opera
Can we integrate IAP cluster with clearPass guest management to work with Opera. I already proposed IAP solution for this Hotel.
MVP
Re: Can we integrate IAP cluster with clearPass guest management to work with Opera
Nilanka,
That should work. To configure IAP with ClearPass for Guest, you may check the following Aruba Solution Exchange: https://ase.arubanetworks.com/solutions/id/37
For the Opera integration part of your question see the following post: http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/fidelio-Opera-controller-integration/m-p/227231
If you have urgent issues, please contact your Aruba partner or Aruba TAC.
