Frequent Contributor I
Capitve Portal customization
A customer is asking how can they customize Captive Portal page in order to control logo(s) and colour scheme.
If I remember correctly, this is a separate piece of work that can be purchased, and is done only in collaboration with Aruba. Thanks.
NesaM
NesaM --ACMP, ACCP--
Re: Capitve Portal customization
Do you mean this?  http://www.arubanetworks.com/assets/ds/DS_ClearPass_Guest_SkinService.pdf
Hi Colin,
That is it, thanks. Customer already has HTML template they would like to be used.
NesaM
