Captive Portal Android issues
Has anyone had issues with the captive portal with Android devices? We have our guest users connect to a Guest SSID which gives an IP and prompts the user to enter an email address into a customized captive portal page.
Laptops, Iphone, ipad, blackberry, and other devices have no issues. Our only problem is with Android devices. User connects to the SSID, gets an IP address but never gets prompted for the guest log in page. They try to browse and do not get a portal page come up.
Running 6000 controller with OS version 6.1.1.0
Contributor I
Re: Captive Portal Android issues
Same issue here and also runing the exact same code 6.1.1.0
Are you still experiencing this issue??
Before you try anything, I would start by upgrading to the latest ArubAOS (6.1.3.5 of this writing), so that you can eliminate the hundreds of issues that have been fixed since then.
