Captive Portal Authentication
Have done the Captive portal configuration but i want when user close the broswer the session must be closed.Please help  me in achieving.
Re: Captive Portal Authentication
This is not possible.
Tim Cappalli | Aruba Security
Ok. Aruba give us the Log out Button with Captive Portal Authentication.I have done the configuration for it, but somehow the log out button goes after login.Could you please give us the solution for it.Atleast after log out the captive portal screen will appear again.
vinit,
Unfortunately the log out button is a popup, and most modern browsers block popups, so your end-user would not be able to see it.
Try disabling the popup blocker in your browser to see if you see the logout popup when you enable it in the Captive Portal authentication profile.
Colin Joseph
Aruba Customer Engineering
