Contributor II
Captive Portal Bypass - ClearPass
Afternoon chaps
Is there a simple way to bypass Web Auth on Captive Portal on ClearPass.
I have an issue with certain iPhone users and a VPN application on a phone, they can't get onto the network becasue they cant access the portal.
Can we push them into a different role using their MAC for authentication?
Re: Captive Portal Bypass - ClearPass
Yes you can
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Instead of web auth service use mac auth service to acheive MAC authentication.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Please explain your desired workflow. How would we get their MAC address if they're not going through a registration process?
Tim Cappalli | Aruba Security
Contributor II
Hi Tim
Workflow is as follows:
1. Device connects to existing SSID gets IP address.
2. Device gets put into new role based on User Defined Rule already configured based on MAC address.
3. New role has firewall policy 'allow all' assigned
4. Device access internet.
I have configured the UDR but the device is staying in the pre-auth role which forwards it to the captive portal. I guess I'm slightly confused with how the flow should be.Thanks
You shouldn’t use UDRs if you’re using ClearPass. Use the Device Registration portal in ClearPass for any MAC address overrides (Guest Device Registration).
Contributor II
Oh OK, I was going by some previuos posts.
I'll try the ClearPass config and let you know.
Contributor II
I take it the Guest Device Portal you mean in the Guest Module - 'Create Device', which I've done and assigned it a Role.
However the device is still trying to do Web Auth according to the Access Tracker and only the once. I've also added the mac to the existing mac auth service, but still cant get it to bypass.
Ignore the WebAuth. It's only generated on initial device registration. Do you have MAC authentication enabled and the ClearPass server group defined in your AAA profile?
Contributor II
Yes thats all in there, but the initial problem is that the iPhone is attempting to put that traffic into its VPN and tunnel it.
