Occasional Contributor I
Captive Portal Migration to Clearpass, help!
Hi all,
I have been tasked with migrating our guest network over to Clearpass and carrying out posture checking on guest devices, I have a captive portal already up and running on our Aruba controller, however am struggling to find a configuration guide for migrating this solution onto our Clearpass device (I am also pretty new to CP), can anyone point me in the direction of some documentation please?
Re: Captive Portal Migration to Clearpass, help!
Thank You,
