Hi
I want to implement Guest captive-portal integration between Fortinet controller and ClearPass, so I created new Web-Login page to be used as the redirected captive-portal page when guests got access to the guest network.
But Fortinet is not listed under the "Vendor-Settings" option, so I think I have to use the custome settings option, but I dont know what are the required values which I have to fill in cells like;
*Submit URL
*Username Field
*Password Field
