Occasional Contributor I
Captive Portal for Users and MAC-auth or no auth for Apple-tv
Hi!
I have set up an environment with wpa2-psk for a Guest-network.
Once connected you need to authenticate to Captive Portal to change role to authenticated.
Now they want Apple-TV's to connect to the network and i dont know how to solve this.
The Idea was to enter their mac-addresses manually since it's not that many and put them in authenticated role this way. But I cant figure out how to do it.
Any help would be appreciated.
/Jesper
Re: Captive Portal for Users and MAC-auth or no auth for Apple-tv
Is this with ClearPass or controller only
Thank You,
Troy
Controller Only environment.
/Jesper
Take a look at user derivation rules in the user guide.
This allows you to override the role based on DHCP fingerprint or MAC address.
Tim Cappalli | Aruba Security
