Captive Portal for both Employee and Guest Access on Captive Portal
Hi
I have a client who is wanting to have two SSID's (One for Employees & one for Guests).  Each SSID is to take you to a seperate Captive portal...
Can this be done with the iAP's?
Thanks in advance Guru's :)
Robbie
Re: Captive Portal for both Employee and Guest Access on Captive Portal
You can only have one captive portal on IAPs.  You might want to configure WPA2-PSK or integrate a radius server for WPA2-Enterprise SSID for Employees.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I thought that may be the case - Thanks for the confirmation.
I know I've seen controllers setup with both Employess CP and a Guest CP in the past.....
You could use another captive portal solution on the second network, such as DNS Redirector.  The only requirement for it to work would be to change the default DNS server handed out by DHCP on that network.
