Captive Portal not always displayed for the guest Wi-Fi
I have a captive portal which is popped after connecting to the Guest Wi-Fi and once username/password is entered, the device connects to the Guest Wi-Fi network.
Let’s say If I remove the Guest Wi-Fi by “Forget This Wi-Fi “ then switch off/on the Wi-Fi on the device; then if I connect again it doesn’t asks for the captive portal with username/password; it auto connects.
Is there a session limit where it stays connected with the previous username/password ?
I have even tried disabling that username on the guest provision but it didn’t help either.
Any help would be much appreciated, thank you.
Re: Captive Portal not always displayed for the guest Wi-Fi
If there is an active session in the controller, you won't get the captive
portal again until it ages out or you delete the user from the user-table.
Tim Cappalli | Aruba Security
Hi cappalli,
Is there anyway to end that session from the controller for that user without deleting the user ?
aaa user delete
thank you
