Frequent Contributor I
Captive Portal on ClearPass Guest with Instant access point
I would like to need you help.
IAP 305 is running 6.5.4.7_64552.
AP settings:-
SSID set as Guest network and Security is point to External splash page.
I create Captive portal profile with IP and URL (Same as on Web Login on Clearpass Guest). https is enabled.
Auth server point to ClearPass.
Clearpass settings:- (C1000V with 6.7.0.35289)
I create a service as Guest Access - Web Login.
Authentication source is Guest User Repository.
Role mapping is Guest Role.
Issue is when connect to SSID. I enter username and password then page shown "Logging in, please wait" and stuck this page for a minute. After that page is redirect to login page again.
On Access Tracker shown user that enter to correctly service.
What should I do? Where am I wrong?
Thank you,
Ratchapas S.
