Occasional Contributor I
Captive Portal on standby controller
I have a pair of M3 controller in a master redundancy environment. So basically, all the work has performed by the active one.
I have 380 APs and more than 3000 users always connected, more than 8000 per day, most of them using captive portal authentication, and so the CPU suffers a lot! The process most involved is httpd, so the captive portal I suppose.
My question is, is it possible to move only the CP authentication on the standby controller, leaving all the other work on the active controller?
Re: Captive Portal on standby controller
The Standby cannot terminate any users or access points while it is a standby controller.  What version of ArubaOS are you running?  Have you considered trying to use 802.1x for some of your users?
Hi Joseph,
yes I was thinking about moving to 802.1X, since even now the
authentication is made towards a RADIUS server. But I can't move now,
that's why I was thinking to move the CP process to the standby controller.
The AOS is a 6.4.3.5
Do you think the controller is being overloaded?
Type "show web-server profile" to see if "bypass cp landing page" is enabled.  Bypass cp landing page has the potential to decrease the load on your controller when using captive portal.  An explanation of the parameter is here;  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/web-server.htm
You can also type "show web-server statistics" to see the current load your web server is taking on:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/showwebserver.htm
Typically your load is when users are authenticating or sitting at the Captive Portal page.  Once they authenticate, the web server load should be gone for that user.  You should really consider 802.1x so that you sidestep a great deal of the issues with Captive Portal and make your client traffic more secure.
Hi Joseph,
yes the CPU is always high
> (Score) #show cpuload current
> Collecting System Statistics. This may take around 5 seconds.
> top2 - 09:44:01 up 1 day, 22:28, 2 users, load average: 3.16, 3.20, 3.27
> Tasks: 348 total, 10 running, 338 sleeping, 0 stopped, 0 zombie
> Cpu(s): 32.6%us, 1.9%sy, 0.0%ni, 65.0%id, 0.0%wa, 0.0%hi, 0.5%si,
> 0.0%st
Mem: 1502772k total, 1257248k used, 245524k free, 37312k buffers
Swap: 0k total, 0k used, 0k free, 488668k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
18303 root 25 0 4516 648 376 R 95 0.0 0:06.48 busybox
18012 nobody 15 0 133m 10m 3728 S 19 0.7 0:02.14 httpd
18092 nobody 16 0 133m 10m 3728 R 13 0.7 0:00.61 httpd
18024 nobody 16 0 133m 10m 3728 R 12 0.7 0:01.45 httpd
18023 nobody 17 0 133m 10m 3728 S 12 0.7 0:01.73 httpd
18062 nobody 17 0 133m 10m 3728 S 9 0.7 0:00.68 httpd
18028 nobody 16 0 133m 10m 3728 S 9 0.7 0:01.75 httpd
18011 nobody 16 0 133m 10m 3728 S 8 0.7 0:00.49 httpd
18020 nobody 17 0 133m 10m 3728 R 8 0.7 0:00.56 httpd
18309 root 17 0 3988 1256 864 R 8 0.1 0:00.45 top2
18063 nobody 16 0 133m 10m 3728 R 7 0.7 0:00.93 httpd
18114 nobody 16 0 133m 10m 3728 S 7 0.7 0:00.79 httpd
18106 nobody 15 0 133m 10m 3728 S 7 0.7 0:00.36 httpd
18037 nobody 16 0 133m 10m 3728 S 6 0.7 0:01.02 httpd
18030 nobody 16 0 133m 10m 3728 S 6 0.7 0:01.40 httpd
18031 nobody 15 0 133m 10m 3728 S 6 0.7 0:01.02 httpd
2122 root 16 0 154m 84m 33m S 5 5.8 319:16.20 auth
2123 root 16 0 257m 176m 23m R 4 12.0 203:48.75 stm
18014 nobody 16 0 133m 10m 3728 S 4 0.7 0:01.66 httpd
mostly for the httpd process.
This is the show web-server profile output
(Score) # show web-server profile
Web Server Configuration
Parameter Value
Cipher Suite Strength high
SSL/TLS Protocol Config tlsv1 tlsv1.1 tlsv1.2
Switch Certificate portal1.wifi.unipr.it
Captive Portal Certificate portal1.wifi.unipr.it
IDP Certificate default
Management user's WebUI access method username/password
User session timeout <30-3600> (seconds) 3600
Maximum supported concurrent clients <25-320> 50
Enable WebUI access on HTTPS port (443) false
Web Lync Listen Protocol/Port Config N/A
Enable bypass captive portal landing page false
Exclude Security Headers from HTTP Response false
Kindest regards,
Luca
Luca,
You should consider enabling the bypas captive portal landing page:
(Aruba7005-US) #configure t
Enter Configuration commands, one per line. End with CNTL/Z
(Aruba7005-US) (config) #web-server profile
(Aruba7005-US) (Web Server Configuration) #enable bypass
<cr>
I would like to try this solution in these days, but since there are thousands of users, I need to use caution. Can that configuration lead to any problem? I have read the explanation but I don't fully understand the real impact for the user. Does the smartphone open anyway automatically the request for inserting the credentials, after being associated to the SSID?
Kindest regards,
Luca
There should be no difference.  Execute the command when you have a maintenence window.
