Hi everybody,
I configured a SSID with captive portal authentication, everything works fine.
I also tried to configure wired user guest access. I found this is the user guide:
"About Trusted and Untrusted VLANs
You can also classify traffic as trusted or untrusted based on the VLAN interface and port/channel. This
means that wired traffic on the incoming port is trusted only when the port’s associated VLAN is also
trusted, otherwise the traffic is untrusted. When a port and its associated VLANs are untrusted, any
incoming and outgoing traffic must pass through a predefined ACL. For example, this setup is useful if your
company provides wired user guest access and you want guest user traffic to pass through an ACL to
connect to a captive portal."
Now I'm stuck with the ACL. I supposed that the "logon" and the "captive-portal" ACLs merged into one ACL should redirect traffic to the captive portal, but all I get is a strange firefox message ("Redirect Loop Error, Redirection limit for this URL exceeded. Unable to load the requested page. This may be caused by cookies that are blocked."). Internet explorer just fails to connect to the internet.
Any suggestion is appreciated...
