Super Contributor I
Captive Portal with Clearpass VLAN VSA
All,
I'm trying to figure out a way for guest users to be sent to a different VLAN when they log into a captive portal. I was told by my Aruba SE that they believe it was possible for a guest user to be handed off to another VLAN if you send a CoA after they log in. I've been trying to get this to work all night and I'm coming up short.
Has anyone got something similar to work?
Thanks for your help!
-Mike
The ArubaOS infrastructure is running 6.3.1.1 and Clearpass 6.2.3.
Re: Captive Portal with Clearpass VLAN VSA
Boston1630,
The only way that has worked is if the initial VLAN that the Captive Portal user is in has a DHCP lease of 30 seconds or less (the controller can provide sub-30 second DHCP leases).  When the user authenticates, ClearPass can send back a role or VLAN that has the new VLAN.  The client will re-dhcp and obtain the new VLAN when the lease expires at the 50% mark and be placed into the new VLAN.
Others have said it can be done with COA, but COA, will resetting the authentication status of a Captive Portal client, does not force it to re-dhcp to obtain a new ip address.  It would be good if someone can show us how it would work that way.
Super Contributor I
CJoseph,
Thanks for the reply! That's an interesting way to go about it. I'm going to send this to my local SE and hope that his source can chime in on this topic. I, too, would like to be able to do it with a CoA, or something similar - that would be a lot slicker than waiting for the client to time out.
Thanks!
-Mike
boston1630 wrote:
CJoseph,
Thanks!
-Mike
Boston1630,
Again, the reason why COA works for 802.1x is that ip addressing and auth in 802.1x are tied together.  In captive portal, it is not, so the client is not disconnected from the network; his authentication state is merely reset, which is independent from ip addressing.
Super Contributor I
CJ,
Any chance there's an equivalent CoA function with Aruba similar to the "Port Bounce" with the Cisco? I know that is a signal to the physical port, but something equivalent might be able to do the trick. This is off course completely spit balling.
Thanks!
-Mike
There is none that I know of that is radius-server facing. Maybe someone can chime in if they know of one.
Frequent Contributor II
Boston,
Is this an open SSID? Are you using clearpass guest as a registration mechanism?
You should be able to do this without a problem.
Super Contributor I
Hi sdr53,
Yep, I'm using Clearpass 6.2.3 and it is providing a web login page. The controller is running 6.3.1.1 and is pointing to Clearpass from a captive portal profile - standard stuff.
Is this something that you've pulled off before? I'm really interested in how you did it.
Thanks!
-Mike
Mike,
Yes i do it and here is how
Set authentication method on service to allow all mac auth. Then set the default role on enforcement policy to return a user role on the controller include a vlan on radius return if you want. that user role should have the captive portal you would like to use for this SSID
The key is the initial role on your controller will never be used because you will approve all requests.
Hope this works for you.
Sdr53,
Thank you for that configuration.
Boston1630, I think wants to start from an unknown client with Captive Portal and switch vlans after Captive Portal authentication. Will your solution work with what he wants?
