Captive Portal with ldap authentication errors
  • 1.  Captive Portal with ldap authentication errors
    Posted Feb 19, 2013 11:56 AM
    Hi everyone, I configured a captive portal with ldap authentication, but if the user in ldap is blacked or invalid, the captive portal just return to the main html with Acces Denied in the URL, is there anyway to pop-up the ldap errors instead to return the index html? PS. I use the internal CP, failover authentication (LDAP, Internal) Thanks
  • 2.  RE: Captive Portal with ldap authentication errors
    Posted Feb 22, 2013 01:15 PM
    There is no way that I know of to get this from the Web interface displayed to the end user.
    you could troubleshoot it by turning on logging
    I would start here I'm not sure if this would give you all that you need but a good place to start:
    #logging level debugging security process authmgr
  • 3.  RE: Captive Portal with ldap authentication errors
    Posted Feb 22, 2013 01:35 PM
    Ddipert is correct.
    Since the LDAP server does not supply the Aruba Controller or IAP with that information, we cannot present it to the user.
