Frequent Contributor II
Captive Portal with simple pass through
Hi:
We've deployed our 802.1x network, and would like users to migrate from our old PSK network.
Is there a way to set up a simple captive portal on the PSK network where I could put a dire warning about the network's demise, requireing only a click or two to proceed through?
Using 3400 controllers with CPPM.
Tony
Re: Captive Portal with simple pass through
Excellent, Thank you.
