Captive portal Templates!
Hello guys!
I was wondering if you guys have nice captive portal templates, in which you can modify without too much effort?
I m really dont know to much of HTML...
Does anyone got templates to share? :)
Cheers
Carlos
Alternetworks Corp
Re: Captive portal Templates!
There should be a couple pages of samples on Arubapedia. If you can't find them let me know and I will send you a link.
Thank You,
Troy
Im searching but i cannot find it...
I know also that partners cannot see everything on the arubapedia... maybe is something you can see and i cannot?
If you can post the templates it would be awsome!
Cheers
Carlos
Alternetworks Corp
Here are a few. Let me know if you have access or not
https://afp.arubanetworks.com/afp/index.php/How-To:_Custom_Skin_HTML_tips
https://afp.arubanetworks.com/afp/index.php/How-To:_Amigopod/ClearPass_HTML_Tips
https://afp.arubanetworks.com/afp/index.php/ClearPass_Guest_HTML_Cheatsheet
This last one is the latest one that Hary did. There are a few links to other pages on the bottom. Let me know if this helps. I might have a few others but Im not in my lab.
Thank You,
Troy
Also here is one that I did awhile back. There is a bug in one (The one with all the buttons) where it dosent carry the MAC on the redirect. I will try to update it next week.
https://afp.arubanetworks.com/afp/index.php/Clearpass_Troys_Code_Samples
Thank You,
Troy
thats clearpass guest templates
I mean normal controller captive portal templates! :)
Cheers
Carlos
Alternetworks Corp
I don't have them posted I will post them when I get back
Thank You,
Troy
Thanks Troy
Happy New Year!
Cheers
Carlos
Alternetworks Corp
Carlos,
Please see some HTML examples for captive portal in the user guide here:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Captive_Portal/Internal_Captive_Portal.htm
Thanks Collin!
I hope Troy got more Templates :)
Cheers
Carlos
Alternetworks Corp
