Frequent Contributor I
Captive portal authentication is not working..
Dear Concerned,
i want to configure the Captive Portal authen for guest users. I have made the captive portal L3 profile for guest user. In this profile what roles i have to select ?? I have select the Default Role "Guest" and Default guest role "Guest". Is it right ?
Now In AAA profile i click on captive portal profile , what inital role i have to select ?
Please guide me... i am a new on ARUBA equipment. using Contoller 620 and AP 105
MVP
Re: Captive portal authentication is not working..
[ Edited ]
in your AAA profile choose, inital role: guest logon
(here is an example)
and dont forget to choose the catpive protal u created:
and press change/apply
also in your l3 profile (your captive portal profile u created or u using) choose guest as the role your guests getting after they passing the captive.
[ Edited ]
Is it possible that you can take the remote session of my PC .. u may access my controller..
MVP
[ Edited ]
A. please delete ur last post (with  the teamviewer details)
B. send me this info on private
C. add me to your skype - asa_2plus
