Regular Contributor I
Captive-portal customization help.
Hi
Controller code: 6.2.1.2
I am trying to figure-out, how to position the user login part, circled in green square, to a specific location on the captive-portal page.
Re: Captive-portal customization help.
For the built-in controller captive portal, you would need to create a custom HTML page and then upload it.
Take a look at this article: https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1649
Tim Cappalli | Aruba Security
