Regular Contributor I
Captive portal from Controller
Is possible from a controller create their own captive portal to limit connection time or I need ClearPass
Re: Captive portal from Controller
In this document you will find a way to define a time and day policy for certain roles
http://www.arubanetworks.com/wp-content/uploads/AOS_GuestAcccess-AppNote.pdf#page47
Thank you
Victor Fabian
Lead Mobility Architect @WEI
It can permit a time limit after establishing a session?
Contributor I
You could time them out with the controller and control access with guest account expiration.
Are you looking for access like:  You can connect for 4 hours in a 24 hour period or something like that?  I think you would need clearpass for that.
If you create individual users in the local user database, their expiry time is enforced after the user logs in::
Colin Joseph
Aruba Customer Engineering
is possible establish time session limit without saving user data in bbdd?
Like Evan W says, anything more complicated and you will need ClearPass Policy Manager.
Colin Joseph
