last person joined: 8 hours ago
Captive portal won't redirect
This thread has been viewed 28 times
  • 1.  Captive portal won't redirect
    Posted Jan 12, 2013 05:07 PM
    I am trying to setup captive portal, but when I connect to my CP enabled SSID,  I do not get redirected to the welcome page.
    I am accessing the SSID via a RAP5, the SSID is in tunnel mode
    Running 6.2.0.2
    I've followed the Aruba OS 6.2 user guide as well as tried the wizard on the controller
    I have the PEF license installed.
    My clients gets assigned the guest-logon role, and can ping www.yahoo.com so I know DNS is working.
    I would appreciate any help to get this working
  • 2.  RE: Captive portal won't redirect
    MVP EXPERT
    Posted Jan 13, 2013 03:36 AM
    Is guest-logon role your initial role? Have you included the captive portal authentication profile on this role? Can you share the output of show user-role guest-logon
  • 3.  RE: Captive portal won't redirect
    Posted Jan 13, 2013 07:39 AM
    My initial role is called guest-guest-logon (the wizard created this).  The Captive portal authentication profile has been included on this role.  I can ping securelogin.arubanetworks.com, which resolves to the IP of my controller.
    Output of show user role guest-guest-logon
    #show user role guest-guest-logon
    Users
        IP              MAC            Name     Role               Age(d:h:m)  Auth  VPN link  AP name      Roaming   Essid/Bssid/Phy               Profile         Forward mode  Type
    172.18.100.22  bc:52:b7:28:19:d8            guest-guest-logon  00:00:00                    leetestrap5  Wireless  guest/d8:c7:c8:fd:b9:a1/g-HT  guest-aaa_prof  tunnel        Android
    User Entries: 1/1
  • 4.  RE: Captive portal won't redirect
    Posted Jan 14, 2013 10:24 AM
    Does the guest VLAN have a L3 interface in the controller?
  • 5.  RE: Captive portal won't redirect
    Posted Jan 14, 2013 12:32 PM
    It does not, do I need one ?
  • 6.  RE: Captive portal won't redirect
    Posted Jan 14, 2013 12:33 PM
    For L3 authentication, the controller needs an IP in the VLAN on the controller.
  • 7.  RE: Captive portal won't redirect
    Posted Jan 14, 2013 04:41 PM
    So adding the L3 VLAN now gets the portal login page to come up, which is great.
    Next problem, when I login to the page using my AD credentials, I receive an authentication failed message.
    For my Captive Portal profile, I'm using the same RADIUS Server group as I use for my Enteprise 802.1x wireless LAN, any ideas why this wouldn't work ?
  • 8.  RE: Captive portal won't redirect
    Posted Jan 14, 2013 05:40 PM
    Ok, so I changed the authentication protocol on my CP Auth profile to MSCHAP and now it's working,  thanks for all your help
  • 9.  RE: Captive portal won't redirect
    Posted Jan 13, 2013 03:41 AM
    Can you ping securelogin.arubanetworks.com from the client?
