Certificate Question : Two CPPM each in different locations using different VLANs
No VIP
When I generate the CSR should it look like this :
CN:
cppm1.cppm.test.com
DNS:
cppm2.cppm.test.com,
IP:
10.2.100.101,
IP:
10.2.101.1102,
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: Certificate Question : Two CPPM each in different locations using different VLANs
Check out the document here:  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=13734
I think you are looking for a clustered deployment.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Colin,  so I guest it shouldn't matter if the SAN is FDQN is attached to a different IP address ?
CN:CPPM1.testing.com
SAN:
DNS:CPPM2.testing.com
IP:10.2.100.200
Thank you
Victor Fabian
If you are using the same certificate for two different boxes, all their ip addresses and DNS names need to be in there.
"SAN – Subject Alternate Name
The subject alternative names (SubjectAltName) extension allows one SSL certificate to be used to secure one Web server with multiple names (such as a different DNS name, IP address or URI). Alternatively, the SubjectAltName extension can be used to secure up to two virtual Web servers using the same SSL certificate. "
"It is imperative that we configure the system with a Fully-Qualified-Domain-Name (FQDN). I’ve intentionally made an error to highlight that if you want to use a Subject Alternate Name (SAN) attribute in the certificate creation it must begin with uppercase DNS, IP or URI not lowercase letters. Multiple SAN’s entries can be entered comma delimited and there can be a mix of DNS and IP values."
Thanks for the confirmation
Thank you
Victor Fabian
Remember if you use the San field the cn field is ignored so you need to put both fqdns in the San field
Cn=server1
San= server1, server2, ip1, ip2
The ips are optional. You only need them if you don't use dns on all redirects.
Thank You,
Troy
Moderator
Victor,
Did we not cover this in email yesterday, or is this a different opportunity? ..... as Colin points out take a look at my CPPM PKI 101 Guide.
Best Regards
-d
ClearPass Product Manager
Frequent Contributor II
If I redo my public certificate and add a 2nd server using the San field. Will this cause 802.1x clients to present error upon next connect because certificate has changed?
Unless you use a supplicant configuration utility to configure your clients, they will most likely be prompted to accept the new certificate.
Tim Cappalli | Aruba Security
