Hi:
I'm trying to setup a shared wireless computer that can be used on different VLANs.
Machine auth works properly, and the machine is pingable on vlan 1 with nobody logged in. This is a good thing, since vlan 1 allows it to reach domain controllers and such.
User A (with a profile that says to use vlan 1) logs in, and all is well.
User A logs out, and the machine is still pingable on vlan 1.
User B (with a profile that says to use vlan 2) logs in and the machine is on vlan 2.
Now, when user B logs out, I see the machine auth show up in CPPM as successful, but from what I can tell, the machine does not return to vlan 1.
It's only when user A logs in again that machine returns to vlan 1. As before, when user A logs out, the machine stays on vlan 1.
Is there any way for the machine auth to force the machine back to vlan 1, after user B logs out?
Tony
