Hi all,
Odd situation here. I am working on various guest login options and ran in to an issue where on the web login editing screen I can't seem to have a check box stay checked. It worked once but then unchecked its self.....
Here is the goal: guests self register and then on the recipt page instead of having them have to go back to the login screen and type in the new credentials, have it so they are automatically logged in.
My solution was to use MAC auth in the self registration page using the paired accounts method. Then I had a link which takes them back to log in sceen where MAC auth is used to login, ie nothing needs to be entered just have to press login. This is where the issue is. On page 131 of the deployment guide it outlines how to use mac auth:
Set auth. method to anonymous
Turn mac auth plugin on and set correct mac format (to match what controller sees)
put "_mac" in to the new field.
check the "Auto-generate the anonymous account option (NOT STAYING CHECKED!)
When they are redirected to the login page the mac address is in the url and the accounts are created successfully with the right mac address.
Now it worked once....so it has to be something that I did!
