Contributor II
Christie Brio and Airgroup
Hello there,
I was wondering if one of you successfully deployed a Christie Brio and a multi network scheme so it becomes discoverable through Airplay?
Please note that it is the wired version of Christie.. with the wireless one we have no issue.
Long story short :
wired christie to wired user device = works fine
wireless Christie to wireless user = works fine
wired christie to wireless= no working at all .
Thx.
Re: Christie Brio and Airgroup
You likely will need to either:
1) Redirect layer 2 advertisements to a tunnel to the controller(s)
2) Trunk the wired VLAN where the devices live to the controller(s)
Tim Cappalli | Aruba Security
Contributor II
That works only when the Brio is on the same subnet. :(
Yes, which is why you need to trunk the wired Brio subnet to the controller so it can see that packets. (or redirect them to the controller via a GRE tunnel)
