FXE
Cisco AnyConnect with Aruba OnGuard
Hi Guys,
I am just wondering, is it possible to have Cisco AnyConnect for my VPN connection then once connected, the OnGuard will run to check its the endpoint's posture?
This AnyConnect will authenticate via Cisco ASA.
Re: Cisco AnyConnect with Aruba OnGuard
Yes
Tim Cappalli | Aruba Security
FXE
Hi cappalli,
thanks that you reply.
can you teach me how to do it? I am now able to authenticate to my VPN, now my issue is that I am thinking for posture assessment and I want it to be done by the ClearPass.
FYI, I am not using ClearPass to authenticate my VPN users, I just want it to be for posture.
thanks a lot in advance
Please work with your ClearPass partner.
FXE
hi cappalli,
i am a partner, I am seeking for possible solution that is why I asked here in the forum.
hope you understand.
thanks
Search AnyConnect on Arubapedia.
