Contributor I
Cisco Clearpass and TACACS. No enable secret
I want to use Clearpass TACACS to authenticate to a Cisco switches.
IOS version.
I used the guide below.
http://community.arubanetworks.com/t5/Security/Configuring-TACACS-on-ClearPass-for-Cisco-switches/m-p/207431#M15726
The problem is that i can authenticate to the switch. But when i login i need to give the enable command and after that a password.
Is it possible to skip this?
Aruba ACCX #749, ACDX #793, ACMP, ACEAP | HPE Master AS
contact: thierry.lubbers@axez.nl
Re: Cisco Clearpass and TACACS. No enable secret
Try including the attribute Type:Shell Name: priv-lvl = Value: 15 under the tacacs enforcement profile
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
