Cisco Switch TACACS - First login fails
Hello all,
I'm doing a trial run of CPPM in hopes to replace Cisco ACS.  I really like CPPM so far, however I'm experiencing what seems to be a frustrating bug or configuration issue.
When trying to log into a Cisco switch configured for TACACS login, my initial login never works, however on the second password attempt it authenticates fine.initial_fail.PNGView from switch CLI
When I check Alert Tracker, I get a login status REJECT, I then pull up the record and see the following errors:alert_message.PNGInitial Login Alert Tracker Record - AlertsI see that it's matching my service but failing after that because it doesn't match my source, role, profiles, etc.
initial_policy.PNGInitial Login Record - Policies
If I click show logs, this is all I get:
Request log details for session: T0000003a-01-5afb08bf
Time Message
2018-05-15 11:20:15,788[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-95 h=223 r=T0000003a-01-5afb08bf] INFO Core.ServiceReqHandler - Service classification result = Cisco-ND-Auth
2018-05-15 11:20:15,788[AAAModuleThread-0x7fde293a0700 h=461 c=T0000003a-01-5afb08bf] INFO AAA.ServiceReqHandler - handleXpipClientResponseEv: Got ServiceObj from ServiceTables for Cisco-ND-Auth
On the second password entry all works fine though!
As you can see, it passed the shell fine.
Furthermore, I can pull up show logs and I get the following:
Request log details for session: T0000003b-01-5afb08c9
Time Message
2018-05-15 11:20:25,292[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-96 h=223 r=T0000003b-01-5afb08c9] INFO Core.ServiceReqHandler - Service classification result = Cisco-ND-Auth
2018-05-15 11:20:25,292[AAAModuleThread-0x7fde293a0700 h=463 c=T0000003b-01-5afb08c9] INFO AAA.ServiceReqHandler - handleXpipClientResponseEv: Got ServiceObj from ServiceTables for Cisco-ND-Auth
2018-05-15 11:20:28,065[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-97 h=239 r=T0000003b-01-5afb08c9] WARN IAT.XpipIATBuilder - populateSoHFromHealthStateCache: Skip looking for SoH in cache since username is not present/empty in request
2018-05-15 11:20:28,065[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-97 h=239 r=T0000003b-01-5afb08c9] WARN Common.MacAddrAttrProvider - HostMac missing, not populating different mac representations
2018-05-15 11:20:28,065[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-97 h=239 r=T0000003b-01-5afb08c9] INFO TAT.TagAttrTableUtil - buildTagAttrTableInput: Connection:Client-Mac-Address is not found
2018-05-15 11:20:28,065[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-97 h=239 r=T0000003b-01-5afb08c9] INFO TAT.AluTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL AuthLocalUser)
2018-05-15 11:20:28,065[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-97 h=239 r=T0000003b-01-5afb08c9] INFO TAT.GuTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL GuestUser)
2018-05-15 11:20:28,065[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-97 h=239 r=T0000003b-01-5afb08c9] INFO TAT.EndpointTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Endpoint)
2018-05-15 11:20:28,065[RequestHandler-1-0x7f4b007e3700 r=psauto-1526398931-97 h=239 r=T0000003b-01-5afb08c9] INFO TAT.OnboardTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Onboard Device User)
2018-05-15 11:20:28,066[RequestHandler-1-0x7f4b007e3700 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_TACACS Started ***
2018-05-15 11:20:28,066[RequestHandler-1-0x7f4b007e3700 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Starting PETaskRoleMapping **
2018-05-15 11:20:28,067[RequestHandler-1-0x7f4b007e3700 h=636 c=T0000003b-01-5afb08c9] INFO Core.PETaskRoleMapping - Roles: TACACS Super Admin], User Authenticated]
2018-05-15 11:20:28,067[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Completed PETaskRoleMapping **
2018-05-15 11:20:28,067[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Starting PETaskEnforcement **
2018-05-15 11:20:28,068[RequestHandler-1-0x7f4b007e3700 h=638 c=T0000003b-01-5afb08c9] INFO Core.PETaskEnforcement - EnfProfiles: Cisco-Priv-Shell
2018-05-15 11:20:28,068[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Completed PETaskEnforcement **
2018-05-15 11:20:28,068[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Starting PETaskSessionLog **
2018-05-15 11:20:28,068[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Starting PETaskOutputPolicyRes **
2018-05-15 11:20:28,069[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Completed PETaskOutputPolicyRes **
2018-05-15 11:20:28,069[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - ** Completed PETaskSessionLog **
2018-05-15 11:20:28,069[RequestHandler-1-0x7f4b007e3700 r=T0000003b-01-5afb08c9 h=635 c=T0000003b-01-5afb08c9] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_TACACS Completed ***
So it seems like all is well, however my first authentication attempt is bombing somewhere, and I'd imagine throwing some kind of application exception that I cannot see.  No idea what is causing it, or how to fix it.
If I log in successfully, I can log back into the same device successfully on the first attempt, it seems to be some sort of cached process that fails initially, then works, then stays cached for about 60 seconds or so, because after that, it starts failing again.
HELP!
Ryan
Re: Cisco Switch TACACS - First login fails
follow up:
This must be a bug, I stood up a second environment from scratch in a lab environment and am not having the same issue.  I'm doubtful it's anything with my domain controller considering it's an internal error with no logs.
I think I'll just blow this server away and recreate from scratch in my PoC demo environment.
Are you using an external authenticaiton source (ex:AD) for this TACACS authentication?
Do you have authorization configured in the service?
Can you share the serverice configuration?
What is teh TACACS server response wait time configured in the switch?
The switch may be closing the connection, before the ClearPass server can complete the authorization against the AD. The second attemp will work because the required authorization data will be available in the Auth Source Cache after the first query and the overall time taken to process the auth request will be lesser during the second attempt.
Thank you,
Saravanan Rajagopal
**Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the post.
I adjusted my timeout from 5 to 10 seconds, it doesn't seem to be causing the issue anymore.  Now I have to figure out what's wrong with the VM that causes it to take so long to authenticate against AD!
Thanks a million for the tip.
For anyone who has the issue- here's the root cause of this.
First authentication attempt had a 7-9 second response time.  Normally it is not this bad.  I went into my AD Source and in the Primary tab, the AD hostname was set to my F5 LDAP pool.  I changed it directly to my DC's hostname and after that authentications were near instantaneous.
Instead of pointing the AD source to a pool, I ended up creating multiple AD Sources (one per server) and added them to my Services as a list of sources instead of just having one source.
This has help improve query response time significantly (from 7 seconds down to <1 s).
