Cisco switch 2950
Dear, If I have a cisco switch 2950 which does not support COA
How can I configure dynamic vlan assignement based on healthy check result
THANKS
Re: Cisco switch 2950
You'd need to use Agent Bounce.
Tim Cappalli | Aruba Security
Dear,
If i used port bounce will that force the end user to change its vlan and ip based on healthy check result if its connected to 2950 switch while there is no aruba controller only cisco switches??
Agent Bounce will cause the same behavior but from the client side
Dear,
Could explain more as i didnt get what u say in the last message
Dear,
I'll try and tell you back
I have two more questions:
1- if there are VDI solution zero client; will that work normal with clearpass?
2- End users dont change their healthy check automatic I have to click the retry button to change the healthy check status.. so I configured session time-out to 60 seconds but i got too many logs in the clearpass. Each 30 (half period) seconds all the 2000 end users will send logs to the clearpass.. so is there any thing to do to make agent send logs only when the status change
Too many thanks bro
Please add more details to those two questions.
