Clear pass captive portal on Aruba 3810m switch
Do i require to install public https certificate on Aruba switch 3810M to work captive portal for wired guest users. I have already installed public https certificate on clearpass. If we need certificate then can i use same certificate for all the switches. I am having Aruba 3810M, Aruba 2930F, Hp procurve 2626 and HP procurve 2520-8 switch model.
Contributor II
Re: Clear pass captive portal on Aruba 3810m switch
No its not required. Self signed certificate should suffice. I have recently deployed 3810M with CPPM captive portal and I used Public wildcard cert on CPPM & self signed cert on 3810M. All worked well.
JayBee
ACDX | CCIE (RnS/SP,DC) | ACCP | ACMP | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Hi
We recommand to have CA signed certificate both on clearpass and NAD devices. Yes ,we could use certificate on mulitple devices.
Pavan
If my post addresses your query give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
Thanks for your response.
If I have already installed public certificate on Clearpass then why do we require public https certificate on Switch.
You do not need a public certificate on the ArubaOS-Switch side....
Tim Cappalli | Aruba Security
