Frequent Contributor II
ClearPass 500 Power Supply
Does Clearpass-500 HW support redundant power supply ?
cannot find its part number
Aruba
Re: ClearPass 500 Power Supply
no, only the 5k and 25k
Thank You,
Troy
Moderator
actually only the 25K supports a PSU.
Best Regards
-d
ClearPass Product Manager
Occasional Contributor I
On a 25K hardware appliance, how can you check if the secondary power supply is instered or not?
I think the out of band mgmt softwares can help like HPE iLO or Dell iDRAC depending upon which flavor of HW you have
Thanks Mathew :-) I reached out to Quamruz in the morning and he said the same thing.
