Contributor II
ClearPass 6.0 Lab
im trying to download the file WinServer2008R2 - ClearPass 6.0 Lab.zip from Arubapedia https://afp.arubanetworks.com/afp/index.php/File:WinServer2008R2_-_ClearPass_6.0_Lab.zip
and the file is corrupt i cant unzip, i m trying to make a demo, if someone have a valid link or file so want to share i will apreciate.
MVP
Re: ClearPass 6.0 Lab
Javier,
Sorry, that file should not be there.
Please use SEEL (instructions on Arubapedia or the partner center) to do your demo's. You may get a Technet subscription (available from Microsoft only until the end of this month!) to build your own domain controller for use in your own lab.
Herman
If you have urgent issues, please contact your Aruba partner or Aruba TAC.
