ClearPass 6.3.0 problems Error Code: 9002
Hi all,
I have a Clearpass demo that I'm working on. Wired users connect with no problem, wireless users on the other don't. I tried with Android and Windows clients and with both devices I get the same response:
Error Code: 9002
Error Category: RADIUS protocol
Error Message: Request timed out
Alerts for this Request
RADIUS Request Timed out
I did read some people that had the same issue but my problem is different. Can you please assist?
When information will be needed?
I can provide Teamviewer access.
Re: ClearPass 6.3.0 problems Error Code: 9002
It is usually the trust chain not being combined on the radius cert.
See the following KB article.
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Apple-TV-failing-authentication-fails-on-CPPM/ta-p/185584
Thank You,
Troy
