Contributor I
ClearPass 6.5.7 Hotfix Patch for CVE-2017-5638 Struts2
Regarding this exploit highly recommend to apply and also change all clearpass password afterwards, a similar exploit was released a couple of years ago, allowing unauthentied users to get the etc/password file.
CVE: CVE-2017-5638
Title
Apache Struts Remote Code Execution Vulnerability
Overview
An unauthenticated remote code execution vulnerability in the Apache
Struts 2 package has been publicly reported.  This advisory details
Aruba's exposure to this vulnerability.
**Aruba Wireless ACMP / ClearPass ACCP / CCNP Professional **
If a reply addresses your issue, please click on the "Accept as Solution" and "Give Kudos"
Re: ClearPass 6.5.7 Hotfix Patch for CVE-2017-5638 Struts2
http://community.arubanetworks.com/t5/Security/Clearpass-and-new-struts2-Vulnerability/td-p/290187
Thank You,
Troy
