Contributor II
ClearPass 6.7 Technical Deep Dive
Hi
A few weeks ago there was a ClearPass 6.7 technical deep dive webinar for partners.
Is it possible to watch a recording of the webinar anywhere on the partner pages?
Regards
Jonas
Re: ClearPass 6.7 Technical Deep Dive
For partner content, you will be able to find it on Arubapedia for Partners.
https://afp.arubanetworks.com
ACMP CWDP
