ClearPass 802.1x with Cisco IP Phones
We are trying to configure ClearPass 802.1x Authentication with Cisco IP Phones (CP-7841 models). The phones have pre-installed Manufacturing Installed Certificate (MIC). We tried installing the Cisco Manufacturing Certificate CA in the trusted CAs in ClearPass, but the phones still fail to authenicate. Any Suggestions? Thanks in advance.
Re: ClearPass 802.1x with Cisco IP Phones
What is shown on the alerts tab?
Tim Cappalli | Aruba Security
Hi cappalli,
I currently do not have access to ClearPass but I can gather this info ASAP. As I remember, it was popping out a message "timed out" on the monitoring tab.
Attached
Frequent Contributor I
Looks like a cert trust issue to me. Please go through below link for " Client did not complete EAP transaction"
https://community.arubanetworks.com/t5/Security/RADIUS-Client-did-not-complete-EAP-transaction-Clearpass-6-3-1/m-p/164042#M12353
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Hi;
 The authentication method for Cisco ip phones is EAP-MD5.
 I hope it helps.
 Angel De la Encarnacion.
ACMP, ACCP, ACDX #544
If this post is helpful, a kudo is appreciated.
