ClearPass Accounting Proxy - No info being sent
Hello all-
I'm trying to use the Accounting Proxy feature to send information to a Fortinet Fortigate device (not FortiAuthenticator!) when I authenticate via an 802.1x wireless service and am having some trouble.
I tried to follow the CPPM TechNote - 3rd Party Enforcement Points (Fortinet) v1.1 pdf  as closely as possible.
I can't seem to get any information to actually *go* to the Fortinet. When I run a packet capture on the Fortinet inside interface, it doesn't appear to ever receive any RADIUS info from CPPM.  I did configure the accounting proxy target, I also edited an Endpoint Context Server to use the ip of the Fortigate (for both logon and logoff, though I'm not sure the example api URL is correct).
When I connect to the wireless SSID I see all of the correct role data etc, but it doesn't appear to ever try to hit the Fortigate. Anyone have ideas? Thanks in advance!
CPPM - 6.6.0.81015
Re: ClearPass Accounting Proxy - No info being sent
You’re running a very old release. I would start by upgrading to either 6.6.10 or 6.7.5
Tim Cappalli | Aruba Security
I've upgraded to 6.6.10. Same results
Occasional Contributor I
I'm in the same boat.  Running 6.7.5 and not able to see any traffic being proxied out.
I'll kick myself for this one, but the problem was that RADIUS accounting wasn't running on my controller. As soon as I turned that on, the appropriate traffic started flowing.
