Frequent Contributor I
ClearPass Backups Questions
On ClearPass, where can I setup automated backups and can they be offloaded easily from the appliance?
Code version 6.4.2.68288
Thank you in advance!!!
Cheers,
David
Re: ClearPass Backups Questions
Please take a look at the link here:  https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/CPPM-External-Data-Puller-Tool-to-automatically-pull-CPPM-backups
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Moderator
Just to add in our next release of CPPM (6.5) we will inclide the ability to define within CPPM backup targets and the have CPPM backup itsself to an SCP/FTP server, rather than 'pulling' the config from the box.
Best Regards
-d
ClearPass Product Manager
looks like the link provided instructs how to pull backups, very nice.  How can I configure nightly backups on the applinces? or does it do this by default?
Thanks...
It's done by default.
Tim Cappalli | Aruba Security
That will be a nice feature, thanks Danny!!
Fantactic!! Thanks Tim!!!
Moderator
A small corection from me... but I'll give you a picture of the UI feature in 6.5.0 as compensation... its will be via SCP + SFTP.
Best Regards
-d
