Contributor II
ClearPass CRL Distribution URL
I am trying to create CRL using URL given to us in format "\\srvcerta\crldist$\". However, when trying to apply it comes back with the message "URL is invalid".
My first guess is that URL format is not correct, but I might be wrong. Any ideas/advices? Thanks in advance.
NesaM
NesaM --ACMP, ACCP--
Re: ClearPass CRL Distribution URL
Doesn't the URL need to be http or https?
The path can be a UNC \\ path but not the URL.
Cheers
James
