Occasional Contributor I
ClearPass Captive Portal with auto login
It has been awhile since I have been under the hood in Clearpass.  I have a functioning captive portal that requires an email address or phone number.  Once entered, the user is sent a password via email or sms.  They then have to login on other page with the password.
I have been asked to remove the need to enter the password.  Is there way to automatically allow access/login after registration without the user entering the password?
-Kevin
Aruba
Re: ClearPass Captive Portal with auto login
You should be able to enable this by enabling the NAS Login option under your self-registration page.
AMFX | ACCX | ACDX | ACMX
clembo,  I already have that enabled in the current setup.
Aruba
When they complete registration, on the receipt page is there not a login button visible?    If not, check your receipt form to see if the field is enabled/visible.
The login button is there. Once clicked, it requests the password.
I would like to remove the requirement to enter the passowrd.  The user supplies an email address or phone number, agrees to the T&C and gets the reciept.  Clicking the login button gives them direct access.
Try creating a new page but not a duplicate one
Thank you
Victor Fabian
Lead Mobility Architect @WEI
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Custom-ClearPass-Guest-page-for-Public-Login-no-username-pass/m-p/137559/highlight/true#M9647
Thank You,
Troy
Troy,
I have set up solution you linked to.  It works but I get a pop message stating "This form is not secure. Are you sure you want to submit it?"
Any idea?
Trusted Contributor I
is your page on http or https? might be your mixing both methods currently and your browser warns about that.
