ClearPass Certificate Not Valid
I am experiencing some issues with the CPPM OnBoard Server Certs. I have a Publically signed CA Cert, which I use as the https cert, and it is validated and trusted by all browsers. I have tried using the same one for the RADIUS Server on CPPM, as well as uploading it a new CA on Guest-->OnBoard. I have tried other public certificates as well. The OnBoard process only works if I tie it to the default OnBoard ClearPass CA, which is all tied to Aruba. I have also tried to upload as a "Trusted Certificate" as well. If I do chain them all together, sometimes I see all of the certs being pushed to the devices on the mdps cert chain. But I still always receive certificate warnings, or "Unverified" messages, even though I do have a trusted public cert. Any suggestions on this? I have consulted the ClearPass Certificate Technote 101 document, but no luck.
Re: ClearPass Certificate Not Valid
Is there a way to resolve this issue on iOS devices?
PLease read this:
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/CPPM-Apple-Onboard-If-statement-checking-for-requirement-of-Root/td-p/91482
Thank you
Victor Fabian
Lead Mobility Architect @WEI
