Trusted Contributor I
ClearPass: Change in 6.2 Patch 5 Caused Problem
In one of my enforcement policies I verify that a device is "MDM enrolled".  This used to be a simple "True" or "False" attribute.  Once I updated to 6.2 Patch 5, all of the devices that authenticate against this policy failed.  Turns out the MDM enrolled values are now true and false, emphasis on the lower-case!  Seems like an insignificant change, but CP is case-sensitive when it comes to the MDM enrolled attribute. To fix this I deleted the old rule and created a new "match regex" rule for MDM enrolled that matches either case: (T|t)rue.
Hope this is helpful to anyone that runs into the same issue.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
