Occasional Contributor I
ClearPass Dataport in Trunk-Mode
Is it possible to use the ClearPass dataport with a network adapter which is configured within vmware in trunk mode (All VLAN IDs 4095)?
Many thanks in advance.
Re: ClearPass Dataport in Trunk-Mode
Poking around, it sure looks like you can - in the Server Configuration panel, look onthe Network tab and you will find VLANs and the ability to create them per interface.
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
